Jon Lane
- 406
- 33
- May 1, 2004
SW,
Florida
I'm curious if this concept has been used on the 4G63: http://highperformancepontiac.com/tech/0410pon_butler/
Defiant said:They'll get a lot more out of that motor with intercoolers. Just water, dry ice, methanol, NO2 or whatever else won't work as well.... which is why intercoolers are used.
If it works on DSMs, it's being done.
If not, it ain't.
The Buick ...Starfire?... of the sixties used WI with its turbocharging. The problem is that you need to keep the water filled, and that's too much for Joe D. Customer. That D's for DORK. Hell, it's hard enough keeping oil and coolant in a car for most people. And nevermind air in the tires, witness the tumbling SUVs.Joesmoke said:it seems that the DSM camp is a little slow to adopt some proven performance modifications IE water injection. People are slowly coming around and excepting it as a good thing, if thats the route you want to take.
91TSiAWD_Mark said:H2O/Alk injection has been used well on hot-air turbo buicks. Early (84-85 iirc) GN's didn't have I/C's, so some people have gone this route.
However, removing a perfectly fine IC setup on a DSM and running straight alky injectioon is like putting on octogaon tires. Sure it'll work, but why try it
Alky injection ontop of the stock IC works very nicely though as a knock supressant...
Defiant said:Wait, wait, wait.
Are you considering running a car on methanol? On the street?
There may be some other kind of meth use involved here.
91TSiAWD_Mark said:Besides the fact its totally illegal and VERY VERY VERY dangerous.
Theres a reason #1) methanol drag cars run on only like 60% meth. #2) they only carry enough fuel for 1 pass. and even then it can explode. Methanol has SO much more latent energy is increadably dangerous....
Defiant said:Oh. Then, iWell, okay.....
I know what to get defiant for christmas, I've seen him use 4 new lock pictures today..he must be running low by now. Who wants to chip in and buy defiant a stock photography disk of lock images :laugh:I'm not sure if alot of you know what you are talking about here and are to quick to say that no something will not work. You can use use methonal/alcohol or NO2 in replace of an intercooler. It all depends on what you intensions are with your vehicle. On a stock apllication vehicle I would say that yes it would be better to use just an intercooler. Alcohol/Methanol have will give you cooler air intake temps and lower the chance of detonation as well. There are plenty of people out there that have been using this method for years.There are plaenty of good kits out there.I use this one www.alkycontrol.comDefiant said:They'll get a lot more out of that motor with intercoolers. Just water, dry ice, methanol, NO2 or whatever else won't work as well.... which is why intercoolers are used.
If not, it ain't.
