alarm problem
gsx4357
103
Sep 26, 2010
maricopa, Arizona
hey i bought my 97 gsx a while back and it was fine...not it developed a problem with the alarm...what it does is every time u open a door or hood the lights keep blinking on and off and if i didnt disconnect my horn it would b blowing as well...
what i want to know is how can i disable the alarm b/c no matter what i do it wont turn off until it times itself off...
i already tried taking the relays out but didnt affect it at all. please help
stick your key in the ignition and it should kill the alarm or in the door and turn it
and theres a little button under the hood thats near the driver side headlight you can pull it off and set it aside like i did
im not sure either
i had a problem were it would just go off in 2 minutes after you lock it or 2 hours after you lock it for no reason and i found the button under the hood and popped it off and it solved it from going off randomly it does still work tho i rolled my window down and locked it then opened the door and it still gos off :hellyeah:
im not sure either
what button is this...i cant find it...i cant see ne button
    • Sdcryan1
