Eclipsemblue
- 356
- 2
- May 8, 2004
####DSMTUNERS,
Maryland
I have my alarm 90% in but im having a problem
the alarm wont arm or disarm with the keychain clicker, it does not respond to any commands from it. I have not installed this one step
"Manual Arm input"
This wire will arm the security system whan a postive or negative pulse is applied to it from an external device
"Manual Disarm input"
This wire will disarm the security system when a Positive or negative pulse is applied from an external device.
I also didnt hook up
"Instant trigger input"
This wire is a ground input for an external sensor or secondary pin switch
"Ground when armed output"
This wire will show ground when the system is armed
Must i connect any of these wires, if so were do they go. The alarm is codealarm425
Again im getting no response from my clicker, when i turn it on, it automatically arms itself and if i tap it the alarm goes off and will not stfu cause the clicker is not working
the alarm wont arm or disarm with the keychain clicker, it does not respond to any commands from it. I have not installed this one step"Manual Arm input"
