1g alarm install
overboosted1g
743
6
Jan 13, 2010
washington, Michigan
My car had an aftermarket alarm with it when I bought it and it worked but I was having no start problems and I removed it and it turned out that it was an ecu issue so now I want to reinstall it but I need a wiring diagram so help me out
Eagle Wiring
^Here is a list all wire diagrams for radio and alarm installation.
1990-92 Eagle Talon Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White Ignition Switch Harness
Starter Black/Yellow Ignition Switch Harness
Ignition Black/White Ignition Switch Harness
Accessory Blue/Black Ignition Switch Harness
Tach White Coil
Brake Switch Green Brake Switch
Trunk Pin n/a Works with Dome Light
Parking Lights Green/White Above Hood Release Gray Connector
Head Lamp Red (-) Switch
Hood Pin n/a
Factory Disarm n/a
Door Trigger Green/Red Above Hood Release Gray Connector
Door Lock Brown/Blue (-) Door Lock Relays above Clutch Pedal
Door Unlock Brown/White (-)
Horn Wire Green/Black (-) Steering Column
Windows Up LF=Red, RF=Red/Blue,
Windows Down LF=Green, RF=Black/Blue
