Air intake w/mass air flow sensor?
eclipsenerd
Mar 1, 2005
St. Louis, Missouri
If I buy an aftermarket cold air intake for my 92 eclipse gs, will it be compatible with the mass air flow sensor??
it all depends where you look if you buy a cheap ebay intake for 20.00 dollars no cause you need the maf bracket otherwise it wont work. my suggest is bomz makes one with a maf bracket i heard, also AEM V2 intakes applications are made too with some modifiying(not much) you can adjust the maf bracket needed that aem gives you. :thumb:
As was said in the previous post, buy a quality intake, AEM or Injen make good ones.
