AGX and Megan Spring Install Help??!?!
95GreenGSX
365
Sep 14, 2006
Chicago, Illinois
Hello,
I am in the process of installing the spring/shock combo. The front ones installed fine but the rear is not going so well. Every thing bolts up to where it should but when i tighten down the nut on the shock the spring still moves. I dont know what to do, add washers etc? anything?
Again, when in tightening down the shock the spring will not compress in the unit itself. When it is fully tightened i can move the actual spring up and down. HELP!!:confused::confused:
you will need to put the weight of the car back on the wheels for the spring to remain stationary. These are "lowering" springs, right? The AGX's have a lot more travel than the springs do.
That's normal. Just lower it a little at a time and make sure it's seated properly.
Does the front springs look a little smaller then the stock springs? just curious.
