agh! more alarm trouble....door locks
918273645
Nov 25, 2004
coquitlam,
what does this mean(its on the back of my alarm brain).blue wire=(+ lock,- unlock out) green wire= (-lock,+unlock out).it is the 2 wire harness for keyless entry. does this mean my alarm brain is both negative and positive switched?so could i just hook these two wires to the 2 brown wires at the door lock relays and they will work with no relays?the alarm is a clifford cyber.i know my car is negative trigger single pulse(thanks to kyledykstra).
thanks alot darr1n
oh by the way my car has factory power door locks.
i forget which wires are which on the dsm side, but that means that BLUE is your unlock wire and GREEN is your lock wire. (since the locks use a negative trigger).
Yea, the wires just have multiple settings for different cars, when programming the alarm, make sure you get it set to negative trigger or you might blow out a relay somewhere.
get some of them taps. i didnt pull anything out to tap in... hard to get at tho. easy :thumb: and keyless IS sweet :) :thumb:
