aftermarket gauges
slowgsr
862
10
Dec 17, 2007
hamilton, ON, Canada
Hi, curious about 3 gauge installs (move to appropriate section if this isn't)
1. Tachometer, I have a 1990 tsi, w/1990 ignition and a AEM EMS, I want to install an aftermarket tach and re-do my cluster with just aluminum plate and a couple gauges. Im looking at the autometer electronic stuff, will I have any problems getting this to work? I know the 90 is different from the 91-94
2. Speedo, I know my speedo is cable, I want to convert to electronic using a 2 G speed sensor, its also a way better signal for the EMS to read, will I have any problems using this signal to power an autometer electronic speedo?
3. Fuel level, I understand fuel sender is about 3 ohms full and i think 90 ohms empty (exact numbers not important, I can look them up later) , can I use the stock sender if I get an aftermarket level gauge that uses these same values?
Thankyou!
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
