Aftermarket Boost Gauge Doesn't Work on Hot Start??
93RS
140
Oct 3, 2011
Brandon, South Dakota
I have a Sunpro boost gauge that works great except for hot starts. If I shut the car off and restart it within 5-10 minutes the gauge still works. Now, if I shut it off and start it up to 2-3 hrs later the gauge reads zero. If you build boost it will read that but when you let off it returns to 0. It only does it for a few minutes, so its not really a big deal but it is kind of annoying. Im curious to see if anyone else has this issue, or if its common with Dsm's. Just curious, Thanks guys.
When it works is it showing proper vacuum and boost? I have that problem only in the summer time with my DEFI Red Racer for my evo. If it's hot outside the gauge will stick on zero and after a couple of minutes will work again. It only happens during hot weather so I am thinking it has to do with the gauge itself. I think you are having a similiar problem as well. Double check your vacuum lines for any leaks or rips to make sure. If everything checks out, you might want to look into another gauge if it bothers.
