After my new engine is installed
4BangerV8Killer
Banned Member
417
Aug 25, 2004
San Martin, California
i know im supposed to prime and and all......what all do i do after its in? i looked around and couldnt really find anything
Boost leak test . I am there now . Rebuilt bottom , stage II sbr head , e16g . Can't :mad: drive it . Vac leaks . :cry: . What break in method are you going to do ? Slow & easy or motoman ?
In order to prime the engine youcan either 1. unplug the coil and crank it over or 2. Use an air ratchet on the crank pulley and turn the motor over several times. I personally have always just unplugged the coil and cranked it. The purpose of this is to get oil into all parts of the motor, and turbo without the strain of the engine running. Should be done after every turbo replacement/removal as well.
Just do not crank it for a long time . 5-10 seconds a crank . Do this several times .
The first time i fire a new engine, i install it without the timing belt and cover. I fill the engine with oil and prime the engine by spinning the oil pump pulley with my electric impact gun.
Well if its a used motor and you didnt do any internal work on it. I would just put oil in...unplug the coil pack crank it over a few times then plug the coil back in and let her rip!
