AFR creeps up as soon as the boost hits
OkieRichard
Feb 3, 2008
Oklahoma City, Oklahoma
My afr creeps up when the boost hits, would anyone mind looking at my logs and telling me what is going on! I have a maft pro, zeitronix wideband, and a pocket logger for information. I have the logs downloaded on the megaupload site, which takes like 45 seconds to download because they make you wait if you don't want to pay for their site.
MEGAUPLOAD - The leading online storage and file delivery service
Have you dont any tuning with the maf pro? If you have added a bunch of fuel but it doew not change, then there is a problem with your fuel system. Looks like your pump isn't keeping up.
Ya i dont see a fuel pump?? Why are you asking us why your AFR is going way lean at 20 psi on a stock pump?? If it is not stock have you tried to raise the fuel at the WOT setting??
Oh yeah, sorry about that, I do have a bosch 044 in pump with 8 AN all the way up. I've also done the fuel pump relay rewire and am running 850's so there is plenty of injector. I've enriched the WOT a lot!! Maybe I'll check the fuel filter, and get back with you guys. I forgot about that little freaking thing I'll also update my profile.
It runs like it is pissed off again. It was the fuel filter, I have one of those little earls filters. There wasn't what I would presume to be very much gunk on it either. Thing is I put it on only a thousand miles ago. This is going to suck if I have to check it often. Another thing that sucks is I had it tuned by some guys on a dyno and I totally ruined that tune. This problem arrived at the exact same time I changed from a manual boost controller to electronic. So I assumed it needed to be retuned, and now... time to start over I guess.
  • Wanted 6 bolt NT water pipe
    • chrisman287
