afpr o-ring same as injector o-rings?
If its the fuellab afpr, then no! I'm not sure about the other ones!
I think Aeromotive afpr are the same as fuel lab, in that case I have three spare o-rings, so if you need one, I can send you one!
Oh, never mind, different o-ring! and no the o-rings on that adapter is bigger then the injector o-rings!
You should be able to match that o-ring with another o-ring at any part store, I know advanced auto parts has a little kit with different sized o-rings, there should be a o-ring in that kit that will match!
Just go to a auto part store and see if they have a o-ring kit, most of them should, if not all part stores!
