afc problem really starting to tick me off
hellraz0r1337
99
Feb 14, 2005
niskayuna, New York
Ok so heres the deal....
when the car is off and floored it reads 100% and when off the gas reads 0%
ive changed the tps and my friend had the same problem on his 1g now ive double checked all my connections and everything
when u press the throttle down 3/4 of the way it starts to read like 6% and then jumps a massive amount and i really need to get my car tuned like yesterday LOL ### HELP
Check for lack of ground, and also check on the voltage readouts. It seems that you might need to reset the AFC. But it could also be that the TPS is not sweeping .
Actually take the TPS of the car and with a Flat screwdriver sweep the sensor from left to right and have someone read the cahnges on the AFC.
Hope this helps!
i will try the sweeping thing but ive gone thru 2 tps and the volts read 4.980 floored and 0.75v idle also when i hit the gas the volts dont start moving till im 3/4 to the floor this is really starting to make me angry
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
