AFC Mount
Spln_Hrd
1,707
8
Oct 20, 2003
Hastings, Nebraska
I bought my car with an afc installed in the car and whoever installed it drilled a hole in the dash and ran the wire down through there. Well it ended up getting stollen out of my car and im replacing it and im not sure how to run the wire through this hole without cutting and splicing the wires. Does anyone know how this can be done? The plastic clip is not going through the hole obviosly and im afraid to cut the harness and then spice it back together.
good luck man. I dont think it should be to hard since everything it color coated. Just make sure to leave yourself enough wire so you can solder it or how ever you are going to connect it but whatever you do get some shrink wrap, that stuff is awsome.(how about some rep points;))
I'm just sick of being a newb, I understand why the rules are in place but I am only a newb as far as posting on tuners in concirned but whatever, doesnt matter I guess
