Talesin
- 1,718
- 36
- Jan 19, 2005
Burbank,
California
Just picked up an AEM UEGO (gauge controller), and can hardly wait for the new exhaust before I put it on.
Fairly sure I understand how this works, but as I've received conflicting advice from certain friends, figured that I should check here before starting in on any harness cutting.
1.) You DO wire the power to the accessory line, right? Friend said to run the power straight back to the battery, and leave it always-on. Seems like it'd shorten battery/sensor life, and having the display on (even just displaying - - -) would be a thief-attractor.
2.) Is there a way to use it to watch EGT? Should I grab a pyrometer as well, or just rely on AFR to expect that the exhaust temps will stay down? Didn't mention it in the manual, but hey. No harm in asking.
3.) I plan to also grab DSMLink. Is there any way to wire up the 0v-5v output from the UEGO to the ECU for logging purposes? From what I've found searching, 2Gs apparently have a problem reading values over 1v, but references were made that 1G ECUs were different in that regard. Short version, I'd prefer to just use one cable to handle it all, rather than dicking around with trying to keep two serial feeds in sync on the logs for later review.
