AEM Tru-Boost on 5557 Turbo?
5558DSM
Jul 26, 2012
Walkerton, ON, Canada
Hello again,
I just re-installed my Tru-boost again after 16g to 5557PTE turbo swap and it does not seem to matter how I install the lines it will not boost over 11psi. I unplugged WGA line and it boosts fine so it is not a leak just wrong line configuration. I read somewhere that this EBC does not work for 50 trim and larger turbos and so far seems that way. I was thinking of restricting the WGA line with something similar to a MBC as it seems there is to much flow to WGA. Seems backwards but I like to control boost from inside the car. Any help is appreciated.
I prefer manual boost controlles. I had issues with tru boost, I think it's an ok ebc but prefer mechanical and reliability over fancyness.
Also, there are different configurations for internal and external wastegates. Make sure the controller is setup for whichever u are running both with ## line routing, and the settings within the gauge. It will explain in the instructions. Sounds like you're just runnin wg spring pressure currently.
Bradikus 7 how are your lines routed. I know that is my issue just can't get them right
I am running internal gate. Worked perfectly with 16g I had previously so I have changed duty cycles with noi results. Just can't figure out why set up the same now as it was with 16g now doesn't work that's why I am wondering line configuration for people with big turbos
