AEM/Snow Methanol Injectoin kit ?
just90gs
128
Dec 5, 2007
west point, Virginia
How does the aem boost-safe work. What do yo use when installing it in a 1g without aem(As in what does that wire going from the aem boost-safe to what in the 1g) im kinda lost and can't seem to find any data on this aem safe-boost. can anyone tell me how it work's and what it does to a tee..
yeah I got that but it does not tell me what that dam green wire goes to.
Copy and pasted from the directions. It clearly states what to hook it to. You need additional parts to make it work.
The green wire on the controller is the 1.7 amp switched ground. This wire can be hooked up to a solenoid that will vent waste gate pressure when activated. Apply 12v to the other side of the solenoid (AEM P/N 30-2400 or equivalent). This output can also be used to trigger a timing retard function in a stand alone ECU or a CDI whenever the system runs out of fluid, thus protecting your engine.
thank's but I got it I just talk to aem
