AEM Fuel / Ignition Controller (F/IC) good?
SvarO
92
Aug 28, 2004
panama, Central America
Hi i was looking the aem site and they have a piggy back, with a lot of options anyone already use it? any feedback?
could be better option over the afc but more cheaper than dsm link for street setup cars,
any input on this aem would be great since,
AEM - Fuel / Ignition Controller (F/IC)
KEY FEATURES
Works with latest OBD-II vehicles including variable valve control
VTEC controller based on Engine RPM and Load
Six (6) injector inputs with simulated injector load used when remapping OEM injectors
Six (6) fuel injector controllers for either remapping of ECU output (+/- 100% trim) or as a stand-alone extra injector driver
21x17 maps with configurable load and RPM breakpoints
Analog in / out for remapping / clamping MAF
F/IC draws power from PC USB interface for quick and easy calibration changes
64kb on-board data logger
Drives high impedence injectors or low impedence injectors with use of Peak & Hold Injector Driver Box
Three (3) channels of timing retard
Supports MAG or HALL sensor types
On board 41PSIA (approx. 25PSI boost) manifold pressure sensor
Windows-based Tuning Software
well unless you have injectors that need more current/draw than the stock setup.. thats not needed.
for our cars we typically dont need an injector driver as oem is plenty, however, if you do plan on running high resistance / large draw injectors then yes you'd need a inj-driver.
assuming you already knew that, i personally dont care for AEM's driver (or cdi's for that matter). anyhow, sorry i couldn't help :)
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
