Adding Talon side molding/"spears"?
96atawd
49
Jul 10, 2013
Havelock, North Carolina
Hello again tuners, I was just curious if it were possible to add the side molding or "spears" (on the doors/quarter panels) from a 2gb (97-98) Eagle Talon onto a 2g Eclipse or 2ga Talon? If so, is it a stick on affair with something like double sided tape, is it a straight bolt on affair with some type of template on the inside of the door skin, or would it be more involved then this, like swapping actual doors and cutting, then welding in quarter panel as it maybe all one piece? I think it might look good on some Eclipses, and pretty much all Talons. Just wondering what would be involved.
Thanks Tuners!
http://farm7.static.flickr.com/6019/6267898109_bb6199c27b_b.jpg
Yes they can be installed on any DSM with 3M double sided trim tape and clips. Use the thread listed in post #2 for correct measurements.
Make sure the surface is super clean before you stick them on and use adhesion promoter
