mindset
- 1,853
- 7
- Jan 3, 2009
Brunswick,
Ohio
Ok. I just recently purchased an ACT 2600, with a street disc. It seriously has only about 20 or 30 "beat" miles on it and I snagged it for $100 with new shifter cables!
With that, the guy gave me this extended push rod and when I searched, it said that was only a band-aid to a failing part. I can't find out what that failing part is. I was looking through the tech articles and I found some information saying that the flywheel step has to be machined to .612, instead of the stock specs. Is the stock flywheel specs the failing part? Or is the pivot ball the failing part? I'd rather do this right while I have the tranny out.
My other problem is making sure this is even a 2600. I searched and found out only some 2600's have raised oval things on the teeth. Lets focus on the above problems, but should I just call ACT with a serial code and see what they say?
