ABS with Evo Brake Swap?
Dyesuperman
523
22
Mar 10, 2009
Minot, North Dakota
Ok, I can't seem to find anything on this. I saw one thread that talked about JDM abs sensors but it didn't go into detail, and I am not sure if that was just because they were using the jdm galant knuckle as well. Anyways, for those that have done the evo brake swap on a 2g gsx with abs using the kmv bracket, how did you retain your abs? Did anything have to be modified?
Thanks,
Caleb
If the knuckles are not being changed then the ABS will still function.
