? about vacum lines
phillabaum03
849
3
Nov 28, 2005
sharpsville, Pennsylvania
If i remove my vacum lines and block them off and remove the box and plugs that the lines run to on the fire wall with it throw a code if i unplug the plugs that go on the firewall?
The problem with ignoring it is that you won't know when a real code was to pay you a visit. :) There are many threads containing resistor values in which you can connect to the plug, same goes for rear O2 and BCS, fooling the ECU into thinking it's still pluged in. Search and you shall find.
