about to hit 120
Look at getting all the fluids changed. Tranny, transfer case, rear diff, and brake fluid if they haven't been changed recently. Now's also the point to look into changing the timing belt and all that goes along with that. And while your at it, check your brakes and tires.
It's not going to suddenly start breaking down at 120,001 miles if you don't do all this, but you should look at getting this done in the near future.
120,000 miles, that's so 100,000 miles ago. :p
LOL when i bought the car the guy said he did the timing belt at 93,000 should i still look into that?
Unless he gave you paperwork showing it was done I would have a shop check the belt out they should be able to tell you for sure unless there a shotty shop then even if it was changed they might try to make a few bucks off of you so make sure its one you trust. I am having mine done in a couple weeks because my crank seal is leaking and my mechanic changes all that when he does the timing belt so I am having mine done at 100k and that might have been the case with yours but if the belt is fine I would just have all the fluids and accessory belts changed.
Did he just change the timing belt or did he also change the rest of the timing components (tensioner and such)?
I hate the fact you have to worry about everything the previous owner did to these cars or what there shotty mechanics did to them. :banghead:
