a588 turbo manifold questions
dsmracer92
34
Feb 7, 2004
neenah, Wisconsin
would the turboexhaust manifold for the 420a motor in our cars would fit the head on my brothers 2002 neon. i believe both blocks are the same but one head is SOCH and the one in our car is DOCH. and the neon head is backwards. let me know if i can use the manifold from one of ours. it would save him a ton of money. thanks
I don't think the exhaust lines up the same way.
If his is SOHC, he should definately check out the local junk yards, as SOHC neons are alot more prevalant then any DOHC eclipse or neon.
On the other hand I noticed you said "turbo" exhaust manifold impling he's going to be turbo'ing his 02 neon. Well Hahnracecraft would know for sure.
A hahn racecraft style will work since the flange is located in the middle of the manifold. If you have a star style where the flange is located in front of port #3, then the answer is no.
Terry
