A/T to M/A swap
Ok here's fact's about the swap. This post may be long but read it!
Im in the middle of swapping my 92 Talon TSI fwd A/T over to Manual.. Anyway i also have a 90 Eclipse GST manual for my parts car. I started by removing the clutch/brake pedal assembly(hardest part!). This was not really hard but time consuming, be pactience it takes time you will figure it out i did. Anyway after you do that Remove the clutch reservoir and hard lines all together(be carefull with the hard lines so you can reuse them) I did and they fit and work perfect. Now go to the A/T car and take the brake assembly out and start cutting your holes for the clutch reservoir and then the center bigger hole. Than take out the tcu(auto trany computer mounted on the firewall behind the center console. Drill the holes for your shift cables. Remove the auot shift assembly and auto clutch line. Than put your new one's in. You must use clutch lines and clutch assembly out of a car that's 91-94 a 90 car will not work. I had to get my cables and assembly out of another car for free though. You should be pretty much done it's not too hard read that article that Dream On posted it will help if you get stuck just PM me i will help you out.
  • Wanted 6 bolt NT water pipe
    • chrisman287
