a quick headlight question for 1g owners
red23
57
May 21, 2004
Newton, New Jersey
i just recently changed my front headlights and side corner lights. after i installed the clear corner lights i put on my blinkers to make sure everything worked right and the corner lights didnt blink. i could have sworn that they did b4. so my question to you is when you turn on the blinker do your corner lights blink or just your front lights? thanks for your time.
I just went to check on my '93 TSI, just the center lights blink, not the corners. Check the bulb, if it's just a 194 or some other single filament bulb, there's no way it can blink.
The corner's do not blink. Only the lights inside the headlight blink. You can modify the wiring and such so the Corners and actual blinkers go back and forth while blinking.
thanks for all the replys guys. i guess i was just imagining the corner lights blinking then!! BacknBlack92ESi how do you modify the wiring to make the corners and blinkers go back and forth?
Well I did have a link of some guy that did it. But now I cannot find it. I'll keep searching to see if I can find something.
ok sounds good. im interested to see how that works. i always thought the corner lights blinked but now that i know they do not i want them to hahha. i do a lot of highway driving so it would prob help if the corner lights blinked so the people next to me can see my turning signal.
I was asking about this a couple weeks ago. For me, only the corner lights blink for my turn signals, not the center lights in the headlight assembly.
