nightspeed87
- 1,761
- 12
- May 2, 2006
Tampa,
Florida
Ok I hope someone can help me here and not just read over this and skip to the next thread.
My engine has 4k on it approx, 6bolt no b/s shafts and had a stock 14b set up on it
even stock oil lines to the turbo...
The turbo started smoking oil... I never tried to fix it and drove it 3k with it smoking under boost ( bad smoking at times ) figuring it was just old and had bad seals despite it not having any shaft play before the rebuild, yet by the time I took it off it had pretty bad shaft play. This is within 4 thousand miles mind you. ( Maybe breaking in motor with it killed it.)
The E316g is on... Still smokes... The exact same amount as 14b.. No shaft play.
I even checked compression, that was good, no blow by, broke engine in on the motoman technique and sealed rings very well. Even went as far as putting a 3dollar fuel filter in the vacuum hose that goes from the head to the intake arm to try and catch oil and it doesnt get any oil in there but a few drops....... Yet I still smoke on a new turbo....
Put about 25 miles on the e316g while smoking... But didnt boost hardly any to try not to hurt it.
Now its getting frustrating....
Time to start trying to fix the issue...
I have real high oil pressure so figured that could be pushing too much oil to the turbo..
Yet i dont see why because im tapped to the head in stock configuration and plenty run to the housing without b/s... I ported the relief valve... Dropped pressure a good amount...
Didnt change smoking issues...
Then i dropped the turn return line... &*%$%#@ found silicone covering a little bit of the exit and entry holes to the turbo drain line... I know just the slightest bit can cause a issue and restrict oil flow... I cleaned it and cleared the restrictions in the drain line and put it back on... Smoked less but still smoked.(Didnt smoke on idle or partial throttle anymore.)
Then i started reading about how crankcase pressure (which i dont think i have much of ) can affect turbo return tube flow... I noticed my pcv was bad.. I changed it...
Bam stopped smoking after about 4 or 5 pulls... ( With a friend watching me go back and forth )
Three hrs later....
*&^%$# started smoking again after driving around happy that it wasnt.
Didnt smoke nearly as bad as before, but still trailed a bit of whiteish blue smoke out the tail pipe, not enough for me to see driving until I floor it, but enough that its a little excessive still. ( Had a friend drive so I could see it.) Smokes more on deceleration
and soon as you punch ( even if just for a momment) the gas a steady stream of smoke comes out, then keeps coming out 3 to 4 seconds after youve let off. Still no shaft play at all. . . . Then i noticed my oil pressure had went back up to what it was before ( as if I never ported the relief valve. Perhaps the oil pressure going back up higher made it smoke AGAIN??)
Maybe relief valve spring not compressing.
Some info on that, the relief valve before porting, warm idled on the last blue line before the red on the gauge, and 4k and up was in the red zone on stock gauge. After porting it warm idled on the middle blue line in the gauge and never quite touched the last blue line before the red. Now its idling on the 2nd blue line again just a day later, and slightly going over that line while driving but not going much past that line no matter rpm. What the hell...
Not trying to throw out a slew of problems at once, but ithought they could be related....Any ideas.This car is becoming a real nusance like it doesnt want to be fixed.
Three hrs later....
