need help idenifying a turbo
tsibribri
304
May 2, 2002
Pennsylvania
im pretty sure its a 16g but wich one? it says td05h then has another number 108a then a dsh then 16 and g on thre bottom of the number 16
also serial number is 040624073 id just like to know what it is it was on my 2g when i bought n i searched and couldnt find a thing
thank you
That doesn't sound like the normal 16g numbering, they usually have 2 lines of numbers. First line doesn't matter, second line (closest to comp inlet) should have some numbers, then a dash. Its the numbers after the dash (last 3-4) that are important.
evoIII 1470
s16g 520
b16g 420
Maybe yours is a 14b, as the numbers you listed don't seem to match up? Can you take a pic or list all the numbers?
ok sory this is the full number and i thinkits gona be a small 16 g correct?
49178-01520
