A/F ratio question using WI
Mitsumanny
Feb 22, 2004
Granada hills, California
To the tuners using water/alch injection, what A/f ratio do you guys run at? I've had mine peak at 12.3 which i think is a little lean, but the knock gauge (dsmchip) doesn't move. I'm boosting w/ a PTE 50 trim at 21 psi, and injecting water/alch with the snowperformance kit. Last time i logged, timming was steady and peaked at 19. Just wondering if anyone else is running a/f ratios as lean as that. Thanx in advance guys.
Snow Performance stage 2 and DSMLINK here as well.
I keep my AF at 11:1. I also keep my timing at a max of +2*. I use boost to control my tune.
I don't use alchohol. I was using smurf piss but as soon as I find a dealer for methanol I will purchase it and mix my own brew for the injection system.
What mixture are you using?
I have a fear that my INJ system may somehow not spray (blown fuse, cracked or leaking connection) during a WOT and I dont want to be on the bleeding edge if that happens.
  • Wanted 6 bolt NT water pipe
    • chrisman287
