A/C Problem, help please!
Turn your A/C down? ha ha. If my car ever gets hot enough for me to turn the A/C on I usually only end up turning the A/C on to the lowest level ha ha. I also do that because my sub and amplifier also require a lot of power. :laugh: She doesn't like it too much when the system is blasting along with the A/C, ha ha.
Sounds like the Compressor. When the Compressor starts to go out they become very hard to turn over and therefore puts a load on your engine. Normally when this happens you will hear the belt squeal when you turn the A/C on.
That's what happened with mine too when I turned it on. It would squeal for a 20 or 30 seconds. When I revved my engine it would squeal too but that's because my water box was shot and wasn't turning as fast as the belts were, whoops :rolleyes: . That alsmost cost me my engine :D
eclipze23109 said:
Everytime i use my air conditioning, my car feels like sh*t! The engine jerks a lot and there is a tremendous loss in power (more than normal). Anyone know what the problem may be? :confused: thanks a lot!
probably the a/c compressor! Just remove the a/c all togather. All the a/c crape ways over 50 pounds.
-Matt
