a/c, heating parts location
Nathan2103
Dec 22, 2002
Malvern,
Hi, a friend of mine has a parts car sitting around and he said anything i wanted off of i could have I was wondering where the location of the a/c condensor and other a/c parts were located as well as parts for the heater such as the heater core, etc. Any info would be appriciated thanks. Oh yeah the car is a 92 eclipse GS N/T
The AC Evaporator is under the dash, on the passenger side.
The compressor is, of course, behind the engine, on the drivers side.
You'll need the 2 liquid and 2 high pressure lines from the engine compartment. They run along both sides of the engine bay.
You'll also need the condensor from behind the radiator.
I do not know if the 1g's that came with NO ac from the factory have the relay box under the hood, but you'll most likely need that as well. It's located between the brake booster and the strut tower, on the drivers side.
Also, I am not sure if the non-ac wiring harness has all of the necessary plugs, so you MAY need to scavange the plugs, and wire them in..
I have my whole AC system out now, so if you need any pictures, let me know, and i'll snap some tonight and put em in my gallery.
