99 gsx slim fan wire help
newdesignz
Aug 3, 2008
chalfont, Pennsylvania
alright so this is that im trying to do. i removed my all of my ac and i want to have the normal cooling fan and the ac fan be wired together so that when the normal cooling fan turns on from the factory harness wires.
so basically i want both fans to run when my normal fan turns on.
im wondering if i just wire both fans to the normal cooling fan harness wires?
can some one please help me out thanks
If you simply wire them together the load will be too much for the single fan relay and it may burn the contacts. You should use a separate relay to power the second fan and just trigger that new relay with the +wire from the normal fan.
is there anyway to have both fans turn on if i run one as the normal cooling fan and if i wire the other to the ac wires? how can i make that fan turn on if i dont have any ac compodents left.
can i just hit the ac witch in my car and the fan will turn on?
