Resolved 99 Eclipse Spyder GS O2 harnesses cut off
Babyboywc54425@gmail
3
Oct 23, 2021
Kearney, Nebraska
Hello!
Need some help here! I just bought this 99 the moron who I got it from did alot of shady things to this car. I can't find the 02 sensor harnessing anywhere...if he didn't cut it off where would it be? He also hacked off the catalytic converter and put the exhaust system damn near up by the the bend of the exhaust manifold...so. No o2 sensors, no catalytic converter, and can't find the harnessing for the o2s please help
so this is the stock header and down pipe on a 2.4L. you can see that the front o2 sensor is right after the flex section on the down pipe. I am assuming this is because the header is a 4-2-1. The 2 pipe section merges at the flex section. Can't put an o2 bung on a flex section and the if the o2 was before the merge to a single pipe, it would only be reading the oxygen content from 2 cylinders.
