97tsi crank but won't start
The_one
117
Oct 30, 2005
denver, Colorado
Could anyone give me some advice on what happen with my car. It cranks but it won't start. I can smell fuel from the exhaust.
check for spark.. then clean the plugs and throw a gallon of fresh gas in there
does it crank normally or does it sound like it has no compression (like a coffee mill) ? if it does..then check your timing .
It sounds like it has no compression
Edit to my last post. . . Check your CAM timing. Not your crank timingLOL . . .
Sounds like you have a timing issue. . .
What do you mean weak? can you see the spark in daylight?
can't adjust timing on 2g. Yes, i can see the spark
Hmmm, I believe I said CAM timing. You most certainly can have your cam timing off a tooth. And since you have a cam angle sensor signaling for ignition timing, though not adjustable, it can signal the wrong ignition timing to the ecu. Improper cam timing can cause two problems at once... And likely result in a hard or no start condition.
