97-99 headlight question
bloody_angel111
188
May 28, 2005
turtle creek, Pennsylvania
Since its so hard to find anyone selling a set of 97-99 healights, I found 2 people on ebay selling one of each light, left and right, and before i bought them, i want to make sure they are both the same lights, and would like it if someone could look at the links and verify it for me.
http://cgi.ebay.com/ebaymotors/ws/e...=8054692720&rd=1&sspagename=STRK:MEWA:IT&rd=1
http://cgi.ebay.com/ebaymotors/ws/e...=8053779340&rd=1&sspagename=STRK:MEWA:IT&rd=1
I would appreciate it if someone can help me to make sure i get the right ones.
Those will not fit right on a 1995-1996 you have a 2ga and 1997-1999 is the 2gb which the front bumper and the headlights are diffenrent it doesn't look but they are. Ok I also see that your car is listed as a 1996 n/t. Is a 1997 or you just want 1997-1999 headlights, if so you will need to use the 1997-1999 front bumper and not only that the plugs are diffenrent so you will have to do some rewiring also.
Confirmed... those headlights would make a matching pair! :thumb:
I think he already knows this and is planning on doing a 2gb front end conversion.
thanks for the replies guys, and i have a blitz front bumper, 97-99 style, so these will fit, i just wanted to make sure they were both the same, but i will ask the one seller if it has a clear corner to it or not before i decide to buy it
Thanks a lot. Also, i wasnt aware of the fact that the plugs are different, and these will require me to rewire them, so is there a link or something that shows me how to do it?
W T F are you talking about?!?!?!? WTF
You do not have to do anything with the wiring. If you get the stock headlights, they will plug right it.
Not if the original car is the 2ga and the lights are from a 2gb, the wiring harness is different as stated above. The connections are a lot different and need to be re worked (projectors are different between the years, look at the plugs).
Yeah there should be a vfaq on it, just look under 2ga to 2gb conversion. Hope this helps.
