2G 97-99 Halfshaft on a 95-96 block
Tyler Davis
5+ Year Contributor
137
36
Feb 18, 2019
Kenosha, Wisconsin
Hello, maybe I’m just being inexperienced but I am curious, just put a longblock into the car (2gb auto) and my Halfshaft does not lineup to the block, it’s off just slightly and it will only bolt up if it’s pulled out a little and then it leaks, is there any way to get a 97-99 Halfshaft to work with the 95-96 block or do I just have to have the matching shaft? Just wondering cause those aren’t the easiest things to find sometimes and mine has no issues with any other block I’ve tried to use. Thanks!
This might help.
This might help.
I don’t know how that thread did not pop up when I searched for it but thank you! if I’m reading it right, I should just need a 97-99 A/C bracket or a 95-96 half shaft then right?
I would say yes. That is your solution
