96 GSX first gear hard to shift
p5150
Jan 10, 2005
Spokane, Washington
Im having some troubles getting into first gear with my AWD, not as much when stopped as compared to while still moving slightly........ I saw some kits on ebay to adjust the shift linkage, is this my problem or am I just going to be better off going with a synthetic fluid to help the synchros out..
Havin Same problem, 95 GSX, If im moving at all, and i mean almost at all, its hard as hell to get er in 1st. At a stop usually not to bad if car has been running a while, when i first start the car its nasty. Any suggestions? I thought maybe it was my bushings but its usually only first
I had the same problem with my car, from what i read on other forums i should have had my master cylinder replaced but i brought it to goodyear and told them what was wrong, long story short they said it was my slave cylinder and basically it never fixed it. A tranny flush would be my suggestion or have a shop look at your master cylinder.
first post sounds like he needs to drain his trany & stick some good stuff in there (Syncro Mesh, GM or pensoil)
the rest of em prolly would improve by doing the same.. maybe check your transfilter too..
