96 avenger turbo ?
dont the avengers use the 420a on the 4cyl versions? if so, most turbo kits for that motor use either a 16g or 20g turbo. nothing too big but still capible turbos, as youre not going to run much boost without building the motor up, 7-9psi at most.
Check www.aseclub.net
There are plenty of setups you can go with in order to turbocharge your Avenger. The Avenger site I listed can help you determine which one you want.
Hahn Race Craft check there site out I had my Avenger turboed. It was fun my car may still be up there
