95tsi awd transmission leak
JamesG
Oct 24, 2011
Spring Creek, Nevada
Its an automatic transmission, I have gone through the car and checked axle seals, outout shaft and input shaft seal to find no leaks. But when I cruise it down the road and back I can see alot of fresh oil. It doesnt leak when it sits, any ideas on whats wrong? Im gonna check any transmission lines for leaks today..
Yeah, under the hood and everything you can see is pretty clean, no leaks or oil anywhere. There has to be a leak on the bottom end of the transmission. Ive removed the tires, exhaust and transfercase to see that there arent any leaks coming from the outputshaft or cv axle shafts. It looks like its all coming from the passenger side and only when its driving. The leak is concentrated around passenger cv seal to the transfer case, pretty much the back end.. I couldnt see any lines damaged.
