95tsi random misfiring
97grnrs
124
Nov 3, 2004
reading, Pennsylvania
Sometimes my tsi while cruising will randomly start sputtering for about 20 sec then go back to normal. I have a 1st gen cas sensor wired in and pretty much new everything on this car .what could poss cause this . Its like it randomly cuts out one cyl or so then comes back to normal
It always had cel on. The key on method to read code won't work for some reason . I wondered if the cas was causing it too. The cel don't bother but the running prob does
It's definitely your cas because you have a 1g one. I came across the same problem but I have a 6 bolt swap. If you have link you can uncheck the misfire though. Google it.
im gonna do the pot mod tomorro, I read that this can cause the car to lean out a bit, will this affect my af under boost now? should i be worried the car will run too lean after this mod or no?
