95 tsi awd won't crank
shortshiftkid
Aug 22, 2012
Evansville, Indiana
Alright so I've got a 1995 awd tsi talon. The car runs and drives great. Yesterday I pulled up to a friends house and turned the car off and it wouldn't start after that. So I checked my connections on the battery, tested the battery and it is still good, checked the starter relay, and it still won't start. All electronics come on and work when key is turned on and when I turn the key to start it the only thing it does is make the relay click. Anyone have any advice in where to go from here?
Dead starter is a good possibility. Check for power at the solenoid terminal on the starter and make sure the starter has a good case ground. No voltage at the solenoid would make the relay click but you won't hear the starter because the solenoid isn't engaging.
