95 gsx
95GSXCNY
Dec 28, 2009
Baldwinsville, New York
just purchased a 95 GSX with 40000 miles on motor, trans, and transfer case. previous owner provided recipts for equipment straight from japan. however, everything is stock what are some good mods to start off with and where are some good online places to buy stuff from
first, i would start with a evo III big 16g. then, fuel upgrades. get yourself a walbro 255 with some 750cc injectors. if you have the money, get yourself a dsmlink. you wont regret it.
i perfer to use extremepsi.com and dsmparts.com
punishment-racing.com is also a very reputable site as well. good luck to you. sounds like you get yourself a nice car:thumb:
when that motor crankwalks,
6 BOLT SWAP FTW!!!
First off, crankwalk is seriously overrated. Second, if the motor, trans, etc. came from Japan, it's possible that it's already been swapped to a 6-bolt. You need to find that out ASAP, as it will affect everything you do from here on out.
Third, there is a list of vendors, a list of vendor sales going on, and here's an upgrade path.
As I'm sure you're new at this, please research your car, what should be done first and foremost, and what is safe for your car to have done to it. Don't skimp on your modifications or upgrades, and do NOT forget the maintenance and supporting modifications. Upgrading your turbocharger or increasing boost requires fuel modifications. Fuel modifications require fuel control. Additional power requires additional engine monitoring, datalogging, and tuning upgrades. Follow the upgrade path, but make it your own. Any questions after you do some research, feel free to ask us.
Any chance you could throw up some pics of the car? Sounds like a nice set up. My advise would be to follow the upgrade path on here and the search feature here is great:rocks:, use it, it has bailed me out several times!
  • Wanted 6 bolt NT water pipe
    • chrisman287
