95 GSX starter removal; bolt location?
Black95_TURBO
73
Dec 26, 2002
Tempe, Arizona
I need to remove my starter and I can't for the life of me find the two bolts that hold it in place. All I can see, or feel for that matter, are the two screws going into the solenoid. Can anyone clearly explain where the bolts are, or post a diagram from a service manual? Thanks
I know this isn't the most exciting thread, but I'm sure somebody out there has the answer. Your help would be much appreciated.
Thanks to beatin4g63s for the help.
Removing the starter:
Follow the black ground wire from the battery to the first of two 14mm bolts, the second bolt is down and to the left if looking into the engine bay from by the passenger side wheel. All that's left is to remove two power sources that connect to the solenoid, one is a clip the other is a 10 or 12mm bolt. A picture of the starter for reference:
