Masterjacko96
- 0
- Aug 14, 2008
Grand Rapids,
Michigan
i got a 95 eclipse gs with the 420a and it for the most time runs like garbage. im getting 2 fuel metering codes. i tried swappin the map sensor and that did nothing, its not missing but it sounds like an injector is sticking open at idle as it will pop and backfire. it gets good mpg on the highway and smooths out in the upper rpms except everyonce in a while it wont idle well and stalls out and wont go past 3700 rpms in every gear likes its hitting some sort of rev limiter. it does that sparaticlly and i almost have to put my foot to the floor and pump the pedal to get it to start but im showing 45psi on the fuel pressure gauge and have a new fuel filter. plugs and wires are new so is the coil. im stumped on the scanner it says my long term fuel trim is -20% and i erase the fuel tim codes and it goes back to that automatically. anyone have any ideas?? thanks
