95 eclipse gs-t no spark 1,4
tehrussell
Mar 2, 2011
hamilton, Texas
Well after getting newly rebuilt engine in car
Getting spark on 2,3
No spark on 1,4
Replaced coil
replaced IGNITION POWER TRANSISTOR
getting power to the coil but its not pulsing
No cells come up when trying to crank
connected car up to monitor not showing any problems
Checked wires they looked like no cuts or any thing
O yeah i checked the ecu no burn marks or bad bulging comp
so since the rebuild you haven't driven it yet correct? if this problem just occurred after you put it back together you may want to check your crank angle sensor and make sure you didn't put it on 180 degrees off.
Yeah it has not been run since iv got it rebuilt ill check it out in the morning hopefully that will be the prob
in front of the intake manifold, and right behind the fuel rail is a electrical plug that controls the pulse of the coil packs, and the clip breaks easily. so try pulling it off and check for wear and tear, or maybe trace wires back to where they come from looking for breaks, i had to replace the plug on mine.
Same thing happened to me. No spark so I bought a new transistor and nothing. I was wiggling around with the wires to the transistor and found it was a loose connction. Just a thought. Hope it helps
so looks like my cas may have been the problem
it was cracked down the center, covered in looks like oil
Got one comming to autozone this afternoon will post up if it fixes it.
Hope it fixes your problem. Good Luck. I think my coils are starting to go out on me getting a random misfire code.
Yep Yep it was the cas the hole time :0 put new one on and got spark on all cyl got it started :)
