95 afpr install help
built420
Mar 1, 2013
Arizona
I'm working on a 95 Mitsubishi eclipse gs. I have a new engine in it with all forged internals Hahns portfueler system. T3/t4 turbo. I'm installing an afpr but don't know how to come at this since the stock for is on the the end of the fuel rail. How do I disable that for and install the new afpr? Any help would be great thanks.
You will disable the factory fpr but leave it in the rail. Then install your new fpr in the return line. If you need to know how you disable the factory fpr read this link.
2GNT.com - How_to_Disable_the_95_fuel_regulator
Ok thank you. Why the return line and not the feed line?
Think about how the system works for a sec. The fuel pump is always pumping so in order to build pressure in the line there has to be a restriction(fpr). The fpr is a pressure valve and since you want the pressure in the fuel rail you put the fpr after it. Anything after the fpr is not pressurized. Put the fpr about 1 to 2 feet after the rail. You may also google fuel system basics to get a good understanding of the system as a whole.
edit* sry if my typing is a bit off. Doing this all from my phone.
  • Wanted 2g Test Pipe/Straight Pipe
    Just wondering if anyone has a test pipe that replaces the stock cat for sale. No preference for...
    • DankYeezy
  • Wanted 4G63 Ecu 1g 1991-1994 Eprom socketed
    Wtb Ecu 1g 1991-1994 Eprom socketed in good working condition!
    • niki_talon
  • For sale 4G63 Stainless T3 header w/38mm wastegate flange
    Same header you can get for $230 on eBay. Like new, only ran for 10min or so. Price is shipped...
    • GRNDSM
    • dsmmario
