93 shifter cables fit 90 tranny?
Talon4ever
111
Feb 15, 2004
Houston, Texas
The shifter cable that goes to the tranny on my 1990 awd talon broke so now my shifter won't go into 2nd gear. I have extra cables but they are from a 1993 Talon. I know that the 90s are a little different because they have different brackets but can the actual cables be swapped?
I have a 90 transmission in my car and it's a 92 that had a 7bolt in it. My car works fine so I don't see why yours wouldn't. Might be different cause of the AWD.
cables should be fine, but the bracket is diffrent on 90's from 93's. Although I wanna say that the shift cables on 90's, both can be adjusted at the shifter but on 93's only the side to side cable can be adjusted.
i have a 93 tranny on my 90. You have to switch over the bracket on the tranny. I'm using 90 shift cables and they are all bent weird. I can shift, just not precise and its sloppy. I have to hit the boneyard and get the bracket for the cable and get new 91-94 shfit cables to go wit my new short throw shifter. Then, it will be awesome.
