92 n/t fwd tranny to 92 gsx
spocks90talon
102
Nov 2, 2004
dayton, Ohio
all right guys quick question, im hating my welded center diff on my 91 gsx and i have a old n/t fwd 92 tranny sitting in my garage from a earlyer project i did a while back, can i bolt that on my 91 turbo motor and awd body? i read a while back that you can use the n/t trannys just fine on a turbo just upgrade the clutch. is this true or what? thanks
I highly DON'T recommend it. The N/T trannies really can't take the beating of a turbo car. I just ripped my tranny apart that was in my car and upgraded to a turbo tranny.
If you were to go with a N/T tranny you would need a new flywheel, clutch, and starter bracket plate
No this wont work due to diff gear ratio's between the tranny and the x-case
