92 Galant vr4 cluster lights and gauge problem
AKeclipseGSX
138
Jul 10, 2010
Chugiak, Alaska
Okay so I'm looking at a 92 galant VR4, and I have some questions on it.
The main problem is the Gauge cluster lights, the boost gauge, the temperature gauge, and the gas gauge don't work. The RPM and speed work fine, but those others don't. The guy said he doesn't know, but the kids he bought it from before were trying to wire it for subs and shorted something out?
So the answer could be as simple as a fuse, but are any of those connected? Just some ideas there.
Thanks!
First check the fuses. Next grab a test light or multimeter and see if theres power where ever those gauges get their power from. If it has power then its your cluster, If it doesnt have power you have to go further down the wiring and either visually inspect or confirm power with a test light. Let us know man, Good Luck!!!
