91 Talon AWD Transmission Problems
850Talon
Mar 5, 2009
Panama City Beach, Florida
To start things off i drive a 1991 Eagle Talon TSI AWD
installed with a
act flywheel
act 2600 w/ street disc
ss clutch line
Heres the problem that i cant seem to figure out how what it is so i know what i need to fix it
My car will start up with no problem but when i got to put it in gear i can feel it go into gear but when i start to let off the clutch pedel nothing happens no stall no grind no movement ive tried this in every gear but heres where the twist comes into play the other day i was just messing around and started the car put it into reverse (cause my DD was parked right infront and if the gear grabbed i didnt want to mess up both my cars
) got on the gas a little bit and shes starts to reverse so then i got to put it into 1st and do the same thing i just did.......... NOTHING :notgood: put it back into reverse and ...........NOTHING again
anybody know what it could be thats my problem is my clutch gone or is it something else?
Thank you for your time
my car had a problem with gears where the gear shift was not even on the gear so it would feel in gear, but nothing would happen. Check to see if all of your shifter linkages are hooked up right too.
Your clutch pedal is really, really out of adjustment. Basically even with the pedal out the clutch is all but disengaged. This is often a problem with a new clutch if you just installed it. Or an old clutch if it is seriously worn out. From your post it is hard to know if you just installed the clutch parts... Or if it was a while ago and the problems just started.
Loosen the clutch pedal linkage. Try again.
i think you figured it out for me as soon as i read your post it hit me
"The 89-94 DSMs have a pedal assembly that over time will cause problems. If you have tried to adjust the clutch and found that you are on the last thread of the adjustment rod chances are that your clutch pedal assembly is worn out. Most often where the end-link and clutch pedal shaft fit together will get slotted out, leaving you unable to get the freeplay adjusted correctly. The main reason for the clutch linkage getting slotted out is the use of heavy pressure plate type clutches. If you're going to use a heavy pressure plate clutch you should inspect your linkage every now & then for damage"
  • Wanted 6 bolt NT water pipe
    • chrisman287
